SketchUp:26.1.252
OS:Windows 11
Ruby:3.2.2
扩展程序:D5 LiveSync (1.7.0.0001)
错误:Fiddle::DLError (Permission denied)
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/fiddle.rb:62:in initialize' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/fiddle.rb:62:in new’
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/fiddle.rb:62:in dlopen' c:/users/administrator/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter/su_d5_plugin_dll.rbe:89:in module:D5dllFunc’
c:/users/administrator/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter/su_d5_plugin_dll.rbe:77:in <main>' c:/users/administrator/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter/su_to_d5render.rbe:2043:in eval’
c:/users/administrator/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter/su_to_d5render.rbe:2043:in require' c:/users/administrator/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter/su_to_d5render.rbe:2043:in ’
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in require’
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/app/sketchup.rb:40:in load’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/app/service/service_plugin__ext.rb:80:in require_and_load' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/app/service/service_plugin__ext.rb:58:in block in auto_load_all’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/app/service/service_plugin__ext.rb:55:in each' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/app/service/service_plugin__ext.rb:55:in auto_load_all’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/boot/boot.rb:53:in <encoded>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/boot/boot.rb:2:in RGLoader_load’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/boot/boot.rb:2:in <top (required)>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/main/main.rb:41:in require’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/piziku/rb/main/main.rb:41:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in require’
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/!!!!piziku.rb:50:in register_extension’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/!!!piziku.rb:50:in <module:Plug>' C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/!!!!piziku.rb:16:in module:Piziku’
C:/ProgramData/SketchUp/SketchUp 2026/SketchUp/Plugins/!!!piziku.rb:15:in `<top (required)>’
问题的步骤:如果问题在进行了某些操作以后固定出现,描述相应的步骤
