问题现象:在飞牛nas的共享文件夹打开就模型丢失一片黑,灯光还在,有时候模型还在,但是材质丢失
复现问题的步骤:如上把原来在群晖nas的d5文件迁移到飞牛后同样是smb共享文件夹,在飞牛nas的共享文件夹打开就模型丢失一片黑,灯光还在,有时候模型还在,但是材质丢失
最近做过什么可能相关的硬件或软件变更:把原来在群晖nas的d5文件迁移到飞牛nas
可能相关的log
LogPakFile: Corrupt pak PrimaryIndex detected!
LogPakFile: Filename: …/…/…/d5_immerse/Content/Paks/m2/Base_8/1.pak
LogPakFile: Encrypted: 1
LogPakFile: Total Size: 3700599
LogPakFile: Index Offset: 3698470
LogPakFile: Index Size: 944
LogPakFile: Stored Index Hash: 5DB6C13B57C142171F0928F491F131BB679D337D
LogPakFile: Computed Index Hash: 21DE16516C0077A65D155586AFC8ED4E707B13EC
LogPakFile: Corrupt pak index detected on pak file: …/…/…/d5_immerse/Content/Paks/m2/Base_8/1.pak
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_4/1.pak.
LogPakFile: Filename: …/…/…/d5_immerse/Content/Paks/m2/Base_4/1.pak
LogPakFile: Total Size: 15896
LogPakFile: Index Offset: 14663
LogPakFile: Index Size: 480
LogPakFile: Stored Index Hash: 1795C50DBF73948C3FF35DF33D81D0BA260130F3
LogPakFile: Computed Index Hash: 13BA58A0E7CC3B70609980C0EB04CEE7BF51E6C8
LogPakFile: Corrupt pak index detected on pak file: …/…/…/d5_immerse/Content/Paks/m2/Base_4/1.pak
LogPakFile: Filename: …/…/…/d5_immerse/Content/Paks/m2/Base_3/1.pak
LogPakFile: Total Size: 3015720
LogPakFile: Index Offset: 3013879
LogPakFile: Index Size: 784
LogPakFile: Stored Index Hash: F6C3E89C2A56AABAB93915088FF8090311753A86
LogPakFile: Computed Index Hash: 3EA4DD2BE4543AD26D939BFB07E853A1D93A5C17
LogPakFile: Corrupt pak index detected on pak file: …/…/…/d5_immerse/Content/Paks/m2/Base_3/1.pak
[2026.01.17-08.24.59:275][316]LogD5: start to load file M:/xxx/xxx/xxx/D5/asset/1.save
[2026.01.17-08.24.59:279][316]LogD5: save original {
[2026.01.17-08.24.59:279][316]LogD5: Error: found inf in save file!
[2026.01.17-08.24.59:287][316]LogD5: load success
复制回windows文件夹又能正常加载
您好,请问该nas路径下除D5外其他文件有出现过丢失或加载不完全情况吗?
方便的话可以将完整日志发送给我们进行排查:
support@d5render.com我们收到文件后会尽快进行测试与处理,感谢您的理解与配合!
已发
你好 我几乎是一样的问题
使用飞牛nas系统的情况下,在nas中打开 .drs 文件 ,会出现丢失模型,或丢失模型材质的问题
使用smb协议
您好,请问具体情况 是该路径下的所有 D5 文件打开都会出现丢失,还是仅个别文件存在此问题?
将文件移动到本地磁盘后再打开,是否可以正常完整显示?
如方便,欢迎补充更多信息,我们会协助您进一步排查。
